Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Set of Helpful Utility Plugins » » » » Post: Set of Helpful Utility Plugins |
Print at Sep 20, 2026, 7:18:33 AM |
| Posted by rkv104 at Nov 4, 2015, 7:28:12 PM |
Set of Helpful Utility Plugins hi friends, I have created a plugin package with 4 plugins that i normally use to expedite my work in sweethome3d. Thought i would share it with sweethome3d community. 4 plugins are 1)enhanced "Duplicate Style" plugin (all credits to original developer) -> Duplicate style (texture, color) from furniture to furniture door to door window to window room to room wall to wall 2)"Intelligent select" -> To select items at current selected level by entering values 1 to 8 (All windows should have string "window" in its name for option 5 to work for selecting windows) for choices 1 to 7 you need to enter number only for choice 8 you need to enter 8,text1,text2,..,textn Option 8 helps to select all objects containing entered texts in there name. You need not have to enter entire text like "windows". only part of text like "dow" will also work. e.g: enter 7,dow,ed to select all windows and beds at current level 3)"Intelligent Hide/Show" -> To hide items at current selected level by entering values 1 to 7. use value 8 to show items hidden using option 1 to 7. Hide: for choices 1 to 6 you need to enter number only (All windows should have string "window" in its name for option 5 to work for hiding windows) for choice 7 you need to enter 7,text1,text2,..,textn Option 7 helps to hide all objects containing entered texts in there name. You need not have to enter entire text like "windows". only part of text like "dow" will also work. e.g: enter 7,dow,ed to hide all windows and beds at current level Show: Show all hidden items by entering value 8 4)"Copy Properties" -> Copy Properties (width, depth,height, angle, elevation) of first selected Object to other selected objects at Current Selected Level It copies properties of first selected object to similar other selected objects. e.g: furniture to furniture door to door window to window wall to wall Plugin installation steps 1)Download the plugin Here is the link for plugin file kept on mediafire... www.mediafire.com/download/i50333o2cysnhor/UtilityPlugin.sh3p 2) Copy the plugin in sweethome 3d plugins directory plug-in may be deployed on the computer by simply copying "UtilityPlugin.sh3p" in the plug-ins folder. In my computer plugins location was it was in location C:\Users\Rohit\AppData\Roaming\eTeks\Sweet Home 3D\plugins 3) Start or restart SweetHome3d after copying file start sweethome3d. The plugins will be available in "PLUGIN" tab in menu General comments Just try if it fits your needs ..otherwise you can always remove it... the plugin file contains the original source code files also.. in case anybody wants to make any enhancements..he has all the rights to do so... Also while using intelligent hide plugin make use of option 8 to display all hidden items......Only undo works in intelligent hide and does same job as choice 8...redo function does not work in intelligent hide plugin... Hope it is of some help to you all.. cheers, |
Current timezone is GMT Sep 20, 2026, 7:18:33 AM |
