Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Partially functional library edition » » » » Post: Re: Partially functional library edition |
Print at Sep 29, 2026, 5:47:01 PM |
| Posted by okh at Oct 26, 2015, 3:42:04 PM |
Re: Partially functional library edition Hi again, had a quick look at your libraries. FurnitureLibraryEditor / SH3D stopped loading after model #5. So it seemed the error was related to model #6. Turns out there was only one specification of colour and diameter, not three (not that easy to spot at a glance, I keep doing similar errors all the time) . If you add the missing properties, for instance with the values in red below, the library works. Also sent you a private message about some copyright issues you may want to consider. ok ## Contributions models id#6=Snduc#neon name#6=Fluorescent strip creationDate#6=2009-04-19 category#6=Lights 2 icon#6=/Neon.png model#6=/Neon/neon.obj width#6=42.0 depth#6=6.4 height#6=5.0 dropOnTopElevation#6=-1 movable#6=false doorOrWindow#6=false ## modification (enkonyito) lightSourceX#6=10.7 21.0 31.7 ## modification (enkonyito) lightSourceY#6=2.2 2.2 2.2 ## modification (enkonyito) lightSourceZ#6=2.5 2.5 2.5 lightSourceColor#6=#aaaaaa #aaaaaa #aaaaaa ## modification (enkonyito) lightSourceDiameter#6=4.0 4.0 4.0 elevation#6=200.0 creator#6=Snduc |
Current timezone is GMT Sep 29, 2026, 5:47:01 PM |
