Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: cut the floor for the render » » » » Post: Re: cut the floor for the render |
Print at Sep 6, 2026, 5:59:55 AM |
| Posted by Puybaret at Oct 17, 2015, 11:11:12 AM |
Re: cut the floor for the render You could import and use one or more large invisible boxes to cut the walls they will intersect, as in the file attached to this post. Don't forget to select the Door or window at the 3rd step of the import furniture wizard, and then disable magnetism when you move the box so the program doesn't try to place the moved box on the closest wall. Note that those boxes will cut only walls and not other doors and windows, and if you import an invisible box as a staircase it will similarly cut all the floors. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 5:59:55 AM |
