Print at Sep 15, 2026, 6:39:13 AM
Posted by musaji at Oct 8, 2015, 4:13:20 AM
Re: Tiny display in Win 8.1
Just downloaded the app to create a floor plan for the house I want to build. Came across the font size issue on my windows 10 laptop (has 2k resolution). Thanks for the fix using the .ini file. I used font size 30.
When you save the file in notepad, make sure to name it using double quotes. It will make sure to preserve the .ini extension, otherwise, notepad will add .txt extension to you filename.
Hope it helps & thanks for the fix.
