Print at Sep 20, 2026, 5:02:43 PM
Posted by okh at Sep 20, 2015, 8:59:19 PM
Re: LED-strips
Nope, just open the file, look at the furniture list (pane left, bottom), there you will see one group of LED strips and one LED strip (placed to the right of the walls). Copy and paste into your drawing. (If you export OBJ / import, you will loose the light-source properties.) The kitchen cabinets (top also has a light-source, set to 0%), you can also ignore. Just select the LED light strip either from the pane or from the drawing and copy. But - it is the very nature of LED strips, that they are narrow, so it is not very easy to spot in the drawing.
