Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Change Texture Plugin » » » » Post: Re: Change Texture Plugin Version 1.1 |
Print at Aug 22, 2026, 11:51:00 AM |
| Posted by digitaltrails at Sep 20, 2015, 8:46:04 AM |
Re: Change Texture Plugin Version 1.1 Change Texture Plugin Version 1.1: https://sourceforge.net/p/sweethome3d/plug-ins/12/ Version 1.1 simplifies the user interface and adds texture icons to the selection panels. ![]() Instructions: The plugin's interface shows three panels. You may interact with the panels in any order. The following interaction would be typical:
Installation: Download the plugin jar from the link at the top of this post and copy it into your Sweet Home 3D plugins folder. According to the plugin Developer's Guide... The appropriate folder depends on your system as follows:
Limitations: Some pieces of furniture have inbuilt textures. These textures won't appear in the From Texture Panel. If you want to use this plugin with furniture with inbuilt textures, first use Modify Furniture to replace the inbuilt textures with textures from the Sweet Home 3D catalog. For example, to experiment with kitchen benchtop textures I first set all the bench unit's tops to normal catalog textures, once that was done I could use the plugin to bulk change the textures for all work surfaces. |
Current timezone is GMT Aug 22, 2026, 11:51:00 AM |
