Print at Sep 20, 2026, 7:11:09 AM
Posted by okh at Sep 17, 2015, 11:41:06 AM
Re: Object in 3D photo problem
Had a quick look at the model. It looks to me as if the body surfaces have two different of materials on front and back, and that the back shines through. In which case you probably will need to edit the model with Sketchup. E.g. first try to explode all groups/components, use the material dialogue to select all surfaces with the body colour, use the entity dialogue to apply the body colour to both sides, and export. However, doing this, you may mess with how the car looks on the inside. Also, it is a pretty elaborate model and the process in Sketchup will be slow. And I guess the model will slow down SH3D significantly too. Maybe you can find another Prius model (although, they do not look quite as nice)? ok
