Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Section view - create 2D cut through the building to complement floorplan » » » » Post: Re: Section view - create 2D cut through the building to complement floorplan |
Print at Aug 17, 2026, 9:02:38 AM |
| Posted by siddie at Aug 20, 2015, 10:10:07 AM |
Re: Section view - create 2D cut through the building to complement floorplan Thank you Hans and OK! The term "cross section" helped me out to search for the right thing and i could find the workaround that OK suggested now as well. This should be enough for my needs. I can remove all the walls and elements except the 1 wall including windows etc., export and import it while rotating to put it on the ground. Then i can add all the measures needed. Excellent, thanks again. Maybe one last question just out of interest: why is it, that the imported .obj file is as unsharp as in the example of OK? Thanks, Siddie |
Current timezone is GMT Aug 17, 2026, 9:02:38 AM |
