Print at Aug 16, 2026, 11:35:52 PM
Posted by HauntedHall at Aug 11, 2015, 3:12:06 PM
Re: Rotating model other than 90 degrees
Thank you for the suggestions, Hans. Model was drawn in sync with the background, but the barns are oriented at about 45* from North. I tried to change the compass orientation, but it did not move the buildings with respect to the screen.
Maybe I was not clear in my explanation, so I'll try another way.
I would like to rotate the model so that the x & y axis of the model are in sync with the x & y grid on the screen (easier to draw the walls). When I am done, I'll move it back into the correct angle that matches the background.
I tried the Rotate plugin but it only works in 90* increments. I looked at the Advanced Edit, but I don't see where I can rotate the entire model at one time. There will be several hundred "walls" when I'm done - it's a floor plan (maze) for a haunted house. It would be too time consuming to move them one at a time.
