Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Problem with pdf plans in A3 papersize » » » » Post: Re: Problem with pdf plans in A3 papersize |
Print at Sep 20, 2026, 1:07:31 AM |
| Posted by hansmex at Jul 9, 2015, 10:05:33 PM |
Re: Problem with pdf plans in A3 papersize Remi, I downloaded both files, and I have the same problems as you. (Kubuntu 14.04 64 bits, SH3D 5.0 beta 8 installed version) The good news: I found a partial workaround in case you need a printed version. Set paper to A3, set margins to 0 (zero), export as PDF. On your printer set printing to "two pages on one sheet". On my A3 printer this results in one image on one A3 sheet. Problem: the image is rotated 90 degrees, and the scaling is not correct. On the correctly produced page, the 810 cms wall is 795 cms on paper. On the workaround page, that 810 cms wall is only 560 cms on paper. I didn't test rotating the paper, meaning setting it to portrait instead of landscape in SH3D. Good luck. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 1:07:31 AM |
