Print at Sep 28, 2026, 3:07:03 AM
Posted by kollmerized at Jun 25, 2015, 1:46:58 PM
Re: floor connects through corners
sadly it doesn't work, the plugin won't work properly because the walls which symbolises pillars won't be recognised very well, resulting in diagonal walls. The same happends if i manually correct the start / endpoints of the walls, at the pillars the walls will be centered leading to diagonal walls.
Some Walls have to start in center of one side of the pillar while others don't (see image in first post
isn't there a way to deactivate the connection of the rooms?
