Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Rename furniture » » » » Post: Re: Rename furniture |
Print at Jul 5, 2026, 8:47:42 AM |
| Posted by enkonyito at Jun 5, 2015, 10:49:20 PM |
Re: Rename furniture The discussion of Wishlist forum continues here. Thank you for the plug-in. It works as expected on my computer. Two small suggestions: 1 - The two characters you chose to surround the room name take up "a lot" of space. Maybe you could add only a "-" (hyphen) after the name? 2 - The plug-in adds "Rename" to the toolbar. Other plug-ins add "PLUGIN" and then add the plug-in under that "chapter". Maybe your plug-in could check if "PLUGIN" is already present, than add the plug-in to that category. If not, create that category. This would keep things a bit more standardized. Thanks again, Hans 1 - I use unusual characters to add the rooms name. What do you think of it '|' ? 2 - Some plug-in uses "Tools" in the toolbar as in the example of Developer's Guide. What-is the standard? I find a "Plug-in" menu would be much more meaningful. As Sweet Home 3D 5.0 will integrate levels at the same elevation, i would try to take into account this feature in the next version of the plugin. ---------------------------------------- EnkoNyito |
Current timezone is GMT Jul 5, 2026, 8:47:42 AM |
