Print at Sep 10, 2026, 7:13:35 AM
Posted by Puybaret at Jun 1, 2015, 1:41:09 PM
Re: Custom 3D Models
If you designed your model with Art of Illusion, you should pay attention to the value in the Max Surface Error field when you select Export > Wavefront menu item:
This value is used to approximate round surfaces to triangles and rectangles that are the only shapes supported by OBJ format. If you use a too small value (like you probably did), this will end up to the creation many super small triangles in a big OBJ file, with no visual benefit.
Try a bigger value until you get a correct result with smooth enough surfaces.
