Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can't Open Home » » » » Post: Re: Can't Open Home |
Print at Sep 30, 2026, 7:47:08 PM |
| Posted by Puybaret at Apr 27, 2015, 10:48:25 AM |
Re: Can't Open Home The second file you sent has the same issue (a file full of zeros). ![]() Sweet Home 3D always run with Java, and if you didn't notice, this is probably because you use Sweet Home 3D installer version which embeds a private copy of Java. Please, choose Help > About Sweet Home 3D menu item and report here the versions you use, like in the following capture which shows version 4.3 for Sweet Home 3D and 1.6.0_45 for Java: ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 7:47:08 PM |
