Print at Sep 30, 2026, 7:47:23 PM
Posted by jbernon at Apr 21, 2015, 12:39:42 PM
Re: No 3D panel with SweetHome 4.5 on Debian Jessie
Thank you for your answer Hans.
I can already use Sweethome through Windoxs 7. I would like to use it through my Linux dist which is the new Debian 8 release (kernel 3.16.2). Using Ubuntu 14 for one app doesn't make sense in my environment.
I will try again to make sh3d working with Debian 8 (also called Jessie). sh3d is part of the main dist packages and it should work. Here are the Debian packages :
- sweethome
- sweethome3d-furniture
Here are the sweethome package dependancies :
- icedtea-netx-common | sun-java6-bin
- javawrappers
- libfreehep-graphicsio-svg-java
- libitext-java
- libjava3d-java
- libsunflow-java
- libbatik-java
- default-jre | java6-runtime
In your opinion, what is to be checked in this stuff ? Is there any probability to get it working ?
