Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Off grid solutions » » » » Post: Re: Off grid solutions |
Print at Sep 13, 2026, 8:18:15 PM |
| Posted by homerbask at Apr 13, 2015, 1:57:46 AM |
Re: Off grid solutions nice house-cottage. Where is it located? I read some of the post though not quite understand because I do not speak English and I'm reading and writing using google translate. the bathroom the best solution is a dry bath. It is economical, easy to do and also you get your own compost for vegetation. I leave a video is in Spanish but I think you understand its operation: https://www.youtube.com/watch?v=Cta6xaE2tKg on the thermal and sound insulation straw is a great even better than the isolates used in building insulation. the bad thing is you need certain requirements for straw does not degenerate over time, humidity etc in Germany was tested fire resistance of a wall of straw. The test consisted in raising the temperature inside the wall slowly up to 1000 degrees Celsius to watch the wall behaves. I spent 30 minutes inside wall is 800 degrees Celsius when the outer wall is at a temperature between 35 ° c There are also other systems to heat your home with the energy of the sun or the earth such as a Trombe wall or a Canadian well tapping geothermal energy. http://www.sitiosolar.com/wp-content/uploads/...ncionamiento-invierno.png on a simple hot water solar heater can help you in summer but seeing those snowfall I do not think it is very hot there ... I feel the translation. I used google translate if you do not understand something explained dimelo and try to explain otherwise, or in other words. A greeting |
Current timezone is GMT Sep 13, 2026, 8:18:15 PM |
