Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Adding external jar file » » » » Post: Adding external jar file |
Print at Sep 20, 2026, 4:00:23 PM |
| Posted by ams.amila at Feb 2, 2015, 11:59:06 AM |
Adding external jar file Hi Puybaret, I'm using your amazing program inside my web application as a design tool. It works well and I need to use external library inside your application (JAR file). The problem is after I deploy application as applet (build successfully) there is an "NoClassDefFound" exception occurred on runtime. I used build.xml file you provided. Can you explain Why this happen? |
Current timezone is GMT Sep 20, 2026, 4:00:23 PM |
