Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor color and texture not rendering properly » » » » Post: Re: Floor color and texture not rendering properly |
Print at Sep 28, 2026, 5:31:14 AM |
| Posted by Puybaret at Jan 19, 2015, 3:56:35 PM |
Re: Floor color and texture not rendering properly I'm aware of this issue and after the multiple improvements I programmed to ensure room cutting in the ground is correct, I noticed it still happens only under Mac OS X with Java 6 from time to time. As it works correctly with Java 6/7/8 under other systems, and also with Java 7/8 under Mac OS X (i.e. with the Java Web Start version), I'm not that motivated to continue trying to fix this issue since it must be a problem in Apple Java itself. Note that the issue appears only at ground level when you're far away and it doesn't appear in photo creation tool. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 5:31:14 AM |
