Print at Sep 10, 2026, 7:06:15 AM
Posted by okh at Dec 20, 2014, 11:39:55 AM
Re: 3D models in test.
I need an open door....
how import open door to sweethome???
while importing i got error, that is the open space was covered by the wall....
To know exactly what you mean, it would be easier if you could share the .sh3d file, but a bit of guesswork:
First, make sure you cross off the checkbox for Door/window when importing your door model, and align door on wall with magnetism on. As of 4.2 SH3D will cut exactly along the model edges to create the cut-out. If the door model has no threshold, the wall will follow the 3 sides of the frame and cover the door. The automatic cut-out will also follow invisible elements of the model.
For a rectangular door frame: Quick workaround, use the Service hatch same size as the door and create the opening. Elaborate workaround, import model to Furniture Library Editor, add SVG M0,0 v1 h1 v-1 z to cut the full rectangle around the model.
If the model has a frame with an open door, and you try to adjust the door depth to scale the door correctly on a thick wall, you will loose the cut-out and need to use the service hatch (or similar) to create the cut-out. Or use a separate door and frame (see SF3D models 334) - with example doors.
Good luck.
