Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Integrating Sweet Home 3D Viewer in a webpage » » » » Post: Re: Integrating Sweet Home 3D Viewer in a webpage |
Print at Sep 3, 2026, 1:33:17 PM |
| Posted by Puybaret at Nov 27, 2014, 7:11:31 PM |
Re: Integrating Sweet Home 3D Viewer in a webpage Sorry I won't, just because I don't want my certificate to be used when there are other solutions. If you want to generate jar files yourself, download source code, install the JDK and Ant (or use eclipse), update the deploy/SweetHome3DViewer.jnlp file found in the project and run the Ant target viewerInstaller. The easiest solution could be to host simply your files elsewhere. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 3, 2026, 1:33:17 PM |
