Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Raised floor in entry way » » » » Post: Re: Raised floor in entry way |
Print at Jul 28, 2026, 3:36:34 AM |
| Posted by okh at Nov 27, 2014, 2:11:46 PM |
Re: Raised floor in entry way You have several possibilities. For instance: 1) Using levels: just draw your entire construction (ignoring the raised floor in entry-way for now). When finished, add another level +6" up. Go to that level and double-click with room tool to create a floor in the entry-way. You could adjust level height 6" down too (in case you need walls starting at that level). The raised entry-way floor will only be visible in 3D on that level (and levels above) unless you select Display all levels. 2) Using a 'platform': Such minor differences in elevation, do not really justify a level, so it is often easier to use an object 6" thick to "raise" the floor. To create this object based on you room: - draw the entire level, - double-click with room tool in the entry-way, - edit room and disable ceiling, - select room and export selection to .obj format, - import .obj file and adjust thickness, - place that object in the entry-way. Regardless of which method you choose, you need to pay attention to the elevation of the doors. Hope this helps. Good luck. ok |
Current timezone is GMT Jul 28, 2026, 3:36:34 AM |
