Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Sunroof » » » » Post: Re: Sunroof |
Print at Sep 27, 2026, 4:20:23 AM |
| Posted by hansmex at Oct 24, 2014, 11:16:08 AM |
Re: Sunroof Curved windows, or arched windows: read and follow the links in this thread If you need horizontal window, you may follow these steps - choose the window you want to insert - export it, then import it again - while importing, rotate the window 90 degrees to make it horizontal - while importing, make sure to check Staircase - you can now insert the window in a floor/ceiling, and it will make a cut-out, just as windows in walls do Another way to do this: - draw a wall that has the size and shape of your roof/ceiling - insert the window you need and make sure it is in the correct place - export wall and window - import wall and window and rotate it 90 degrees If this is not the correct answer, share a picture of what it is that you need. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 27, 2026, 4:20:23 AM |
