Print at Sep 27, 2026, 7:48:39 AM
Posted by okh at Oct 23, 2014, 2:22:36 PM
Re: The dependence of the thickness of the door or window, the thickness of the wall in which they are embedded.
Maybe the easiest of all is to use a separate frame and a door without door-properties?
Allows you to change opening or hide the door altogether. Makes for a tidier work-space and to combine different doors and frames. But preferably so the 2d door-frame displays the way the door opens, like this.
You will see that the scaling of the frame (how much the door frame protrudes from the wall) is still a "problem". But on a much smaller scale - and it is normal to use thicker framework on an outside wall.
See SF 3D 334.
