Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Is it possible to create glass wall? » » » » Post: Re: Is it possible to create glass wall? |
Print at Aug 17, 2026, 1:29:10 AM |
| Posted by okh at Sep 11, 2014, 2:20:19 PM |
Re: Is it possible to create glass wall? Ah yes - I forgot to add that the glass wall is set to be reflective in rendering q3/q4 (using g sweethome3d_window_mirror in the .obj file - like a mirror - see the rest of the thread). This example - glass_walls_reflection_and_not.sh3d - shows the same window with reflection (marked with a danger sign) and without reflection. I posted the two other windows used in the example too in case the lab does not want reflective glass walls. As for the general transparency, you could change the d value in the .mtl file. But I guess it is the rendering you were after... ok |
Current timezone is GMT Aug 17, 2026, 1:29:10 AM |
