Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: To create an opening in a work-top ? » » » » Post: Re: To create an opening in a work-top ? |
Print at Sep 19, 2026, 2:36:29 PM |
| Posted by okh at Aug 18, 2014, 1:36:17 PM |
Re: To create an opening in a work-top ? Very nice work, and I think your 2D compromise is a good idea, but admit I think the 3D models look a lot nicer and more in line with the quality of your models. ..25 x 10 = 250 possible combinations.... - clearly not sustainable... For my own use, I add the sink to the worktop when I make the model - but then I only consider a few sinks and only use the 60cm modules and 3cm worktop. Even if you can add texture later, it would make for too many combinations. I also once tried using a separate level for the worktop (room = worktop where floor thickness = worktop thickness). And while that let me use the staircase SVG cutout for the sink so I could move it on the worktop, the solution was a bit awkward (and could not be integrated in a furniture library). So I guess the solution proposed by Hansmex is the most appealing. ok PS You should also note that there once were slight differences in the models sold in the different countries, but I think kitchen models are now all uniform with the most recent modular system. |
Current timezone is GMT Sep 19, 2026, 2:36:29 PM |
