Print at Sep 19, 2026, 4:12:17 PM
Posted by Puybaret at Aug 8, 2014, 11:45:30 AM
Re: Measuring walls from border rather than middle?
You could create rooms instead of walls, then double-click on each room to create walls around it. But if you use this method, as soon as you create more than one room, this might require that you remove walls in double that will appear at the limit of rooms beside an other one, and/or move walls in case you want to adjust their thickness.
is there a way to connect walls together that were created separately?
If the plug-in mentioned by Hans doesn't feet your needs, you may simply remove the wall and draw it again. Be sure to double-click when you finish the wall to connect it. Note that only one wall end can be connected to another wall end.
