Print at Sep 19, 2026, 3:32:16 PM
Posted by Puybaret at Jul 24, 2014, 11:36:08 PM
Re: Import 3D format
Basically, you should decode the file format you want to import, then try to create Wall and Room instances that the imported data contains. Finally, add these objects to a new Home instance that you'll display at the screen by inspiring you from SweetHome3D main class source code.
