Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Invisible floor on upper level room. » » » » Post: Re: Invisible floor on upper level room. |
Print at Sep 19, 2026, 6:43:28 PM |
| Posted by hansmex at Jul 16, 2014, 7:59:26 AM |
Re: Invisible floor on upper level room. Jeremy, You didn't create floors in your plan, so it's logical that you can't see them. Click the Floor button (to the right of the Walls button), then double-click in each room. Problem solved! Hans Tip: read the Plug-in manual, install the AdvancedEdit plug-in and use the Connect walls function to connect the walls in the top-left corner of your design. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 19, 2026, 6:43:28 PM |
