Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: why "Recompute walls" is disabled? » » » » Post: Re: why "Recompute walls" is disabled? |
Print at Aug 22, 2026, 3:04:36 AM |
| Posted by okh at Jun 26, 2014, 10:26:56 AM |
Re: why "Recompute walls" is disabled? Make sure that there are no openings in the walls of the room, delete the room, and then use the Room-tool (Create room ) and double-click. You now should have a room that fits the walls exactly - and the option of recalculating the room should be available if one wall extends outside the room. It is also possible to split the wall manually. Select the wall, use Plan>Split wall, and drag the new wall connection to where you want it. Good luck. ok |
Current timezone is GMT Aug 22, 2026, 3:04:36 AM |
