Print at Aug 22, 2026, 3:04:24 AM
Posted by okh at Jun 24, 2014, 10:46:48 AM
Re: why "Recompute walls" is disabled?
If I understand this correctly:
Changing the wall colour/texture from the room properties works on walls connected to the room. But as one wall can be connected to several rooms, the "Recompute walls" box will split the walls, so you do not apply the colour/texture on the part of the wall that extends outside the room.
So, it there is no "Recompute walls" box, there is no need to split (recompute) walls. And therefore no need to enable it as it would do nothing anyway.
But maybe you have also moved your room or a wall slightly, so the room doesn't touch all walls. In which case you can delete the room, and then use the Room tool and double-click inside the room to make the room fit exactly.
Hope this helps.
