Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Objects turn into black in HQ render » » » » Post: Re: Objects turn into black in HQ render |
Print at Sep 6, 2026, 9:34:31 AM |
| Posted by Puybaret at Jun 3, 2014, 3:29:04 PM |
Re: Objects turn into black in HQ render Long time afterwards… While testing on your file a bug correction that fixes issues with unexpected black dots in SunFlow, I discovered that your project contains some 3D models with a zero dimension (height or depth), and this provokes some black surface on the rendering. As from version 3.2 (the version that was released just after the one you used to edit your file), Sweet Home 3D avoids to store 0 values during furniture import, this can't happen anymore. If you still want to fix this issue in your file, you should update your version of Sweet Home 3D, look for furniture with a 0 width, depth or height, delete them and replace them with a newly imported plan or box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 9:34:31 AM |
