Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: obj Transparency? » » » » Post: Re: obj Transparency? |
Print at Sep 30, 2026, 7:50:04 PM |
| Posted by pencilart at May 28, 2014, 3:48:47 PM |
Re: obj Transparency? I had forgotten that transparency only works if the item is named sweethome3d_window_pane I'm not sure about the mtl file, I've never looked at it to compare. Editing the mtl file for transparency does not work for some reason. Dunno if that has something to do with what software was used to create the item or not. Right now, the mtl files and obj files are not assigned to any software on Windows 8, and as far as I know it should stay that way. But when you edit such files, Win8 will assign that app as default. SO annoying. So, Okh, have you ever done any 3d modeling yourself? If you haven't, try it! :-) |
Current timezone is GMT Sep 30, 2026, 7:50:04 PM |
