Print at Oct 3, 2026, 9:41:20 PM
Posted by Puybaret at Apr 15, 2014, 6:13:38 PM
Re: Edit the furniture list
You may have encountered a similar issue to okh , i.e. the preferences (including imported furniture) are not saved anymore because you entered many different words in Sweet Home 3D.
Waiting for next version, you can fix this issue following these instructions:
- quit Sweet Home 3D
- find the preferences.xml file in Sweet Home 3D private directory (under Windows 7/8, it's C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D)
- create a backup of this file (in case you modify it incorrectly)
- edit it with any text editor
- find in the text the lines that contain autoCompletionStrings
- delete the line
- save the file
- relaunch Sweet Home 3D
- your preferences are saved again correctly. smile
Is there any way to access the saved feature list on the hard-disk somewhere, and then change it using the Furniture Library Editor?
Please try the previous tip first.
Then, you can export all the furniture you individually imported in Sweet Home 3D with the ExportToSH3F plug-in. Once you installed this plug-in, choose the new menu item Furniture > Export imported furniture to SH3F... to create a SH3F file that you can edit with the Furniture Library Editor.
