Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: how to prevent Sweet Home 3D adjust mm value to .001 ? » » » » Post: how to prevent Sweet Home 3D adjust mm value to .001 ? |
Print at Sep 29, 2026, 6:22:09 PM |
| Posted by hexidiot at Apr 11, 2014, 9:00:03 PM |
how to prevent Sweet Home 3D adjust mm value to .001 ? Hi Sweet Home 3D members,I just downloaded this software (portable version) and trying to draw some walls, but I notice some weird issue regarding the .001 My preferences is set using unit MM, magnetism disabled, wall thickness to 120, height to 2500 and floor thickness to 500. First, I draw walls, after that I pressed ESC after the all walls are closed I modify the start and end value to reflect the actual building, then I notice, no matter how I change some value, there will be .001 prepend into it. Could I set software to no decimal value? I just need precision to mm level. Thank you. ![]() |
Current timezone is GMT Sep 29, 2026, 6:22:09 PM |
