Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: save scene » » » » Post: Re: save scene |
Print at Sep 19, 2026, 5:00:00 PM |
| Posted by Puybaret at Apr 11, 2014, 11:06:21 AM |
Re: save scene With a plug-in, the only way I can see could be using the setVisualProperty method in Home class. Be sure that all the objects you store there implements java.io.Serializable interface. Without a plug-in, you will have more freedom but it will be more complicated, since you will have to create a derived version of Sweet Home 3D, by subclassing SweetHome3D class, to override its getHomeRecorder method and return a different HomeRecorder instance. If you go that way, you can also override createHome to return a Home subclass instance of your choice. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 5:00:00 PM |
