Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to insert a roof window? » » » » Post: Re: How to insert a roof window? |
Print at Aug 19, 2026, 5:41:24 PM |
| Posted by Puybaret at Apr 8, 2014, 8:30:49 PM |
Re: How to insert a roof window? Until now, a wall can be only vertical and Sweet Home 3D doesn't know anything about roofs (even if it can handle ceilings). So, only workarounds are possible. One could be to transform a wall with a window as a roof part with a window: - draw a wall at the same size as the roof part you want - place a window in the wall (for example the fixed window) - eventually change the textures of the wall - select the wall and the window(s) - choose 3D view > Export to OBJ format menu item to save the selection in an OBJ file - import the exported OBJ file, and rotate it if needed at the second step of the furniture import wizard. Hope you can handle it ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 19, 2026, 5:41:24 PM |
