Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.4 » » » » Post: Sweet Home 3D 4.4 |
Print at Sep 14, 2026, 10:25:20 AM |
| Posted by Puybaret at Apr 4, 2014, 4:09:34 PM |
Sweet Home 3D 4.4 Hi, Here's a beta version of Sweet Home 3D 4.4 that you can test. This version contains the following new features: - an improved texture chooser with a tooltip displaying the texture under the cursor at a larger size, a search text field to filter textures list, the ability to rotate textures and a list of the chosen textures recently used during last session ![]() - in the materials choice pane, the shapes using the selected material now blink in the 3D preview, and the 3D preview displays modified textures at the good scale when the default size of the 3D model is very small - improvements in SunFlow to avoid black dots more often and support transparent textures better - new Edit > Select all at all levels menu item with feedback in level tabs showing level names outlined with selection color (while all levels selection is active, it's possible to unselect / reselect objects with shift key in the plan, move selected objects but not duplicate them) ![]() - new dropOnTopElevation property to place objects on others at a preferred elevation (for trees, sinks, shelves, chairs...) - new Furniture > Reset elevation menu item to reset the elevation of an object when you move it around - KMZ file format support (even if it's just a ZIP file containing a DAE file, now it's selectable in file choosers and drag & drop) To test the dropOnTopElevation property, be sure to use the new version 1.4 of the furniture libraries that you can download with the following links: 3DModels-BlendSwap-CC-0-1.4.zip 3DModels-BlendSwap-CC-BY-1.4.zip 3DModels-Contributions-1.4.zip 3DModels-KatorLegaz-1.4.zip 3DModels-LucaPresidente-1.4.zip 3DModels-Reallusion-1.4.zip 3DModels-Scopia-1.4.zip 3DModels-Trees-1.4.zip Please also try if SunFlow works better for you, and don't hesitate to report any issue. You can test the transparency on texture with this new curtain that will be released in next version of furniture libraries. [Notes from developer: - updated links to furniture libraries] - Sweet Home 3D 4.4 was released on June 12, 2014] ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 14, 2026, 10:25:20 AM |
