Print at Sep 10, 2026, 7:12:56 AM
Posted by okh at Feb 16, 2014, 10:35:31 PM
Re: exterior-door-03.zip
If you import an object, checking the Door/Window checkbox, it will adjust to the walls and cut the correct opening. It will also behave like a door in the 2D view, but if you want the 2D view to display the door opening etc, you need to use a door which also supplies these properties (like the ones in the pre-installed collection). The file you mention, is an .obj file which does not support such extra features (wall thickness, door opening/angle, etc).
PS. It is possible to add the extra features, but you must do it yourself by imporint the model into a library and edit the PluginFurnitureCatalog.properties. This thread will explain the properties you need to add: http://www.sweethome3d.com/support/forum/view...d,2006_lastpage,yes#17627
