Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I draw/paint/write something on the surface of an object? » » » » Post: Re: Can I draw/paint/write something on the surface of an object? |
Print at Sep 10, 2026, 12:35:25 AM |
| Posted by okh at Dec 20, 2013, 9:02:08 AM |
Re: Can I draw/paint/write something on the surface of an object? Simple answer is yes. In SH3D you can apply a different texture to each side of a box (provided they are assigned different names) or apply one texture to the entire box (as the linked thread indicates). With AoI you can do the same. Or, as long as the AoI object has different material names fo the different surfaces, you can later assign bitmaps to the named surfaces from SH3D. In your case, the simple wardrobe cuboid, the simple workaroud would be using two boxes in SH3D: one the wardrobe itself, one very thin one with the doors that you place on the front of the wardrobe. You use one material for the wardrobe and one for the door. Then you can group the two objects to simplify moving it around later. ok |
Current timezone is GMT Sep 10, 2026, 12:35:25 AM |
