Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Custom Door & window in 2D » » » » Post: Re: Custom Door & window in 2D |
Print at Aug 22, 2026, 3:43:12 AM |
| Posted by okh at Oct 30, 2013, 9:44:16 PM |
Re: Custom Door & window in 2D Ah well, it really seems you need to dive into the world of sh3d properties files. - Get the FurnitureLibraryEditor (in the downloads). - Import your OBJ/MTL files (zipped) - drag and drop. - Save the library file, rename it <xxx>.zip - Extract the PluginFurnitureCatalog.properties - In this text file you will find all the properties used by sh3d for your models. - http://www.sweethome3d.com/support/forum/view...ad,2006_lastpage,yes#8919 will show you the properties you need to add for your windows/doors. - put the PluginFurnitureCatalog.properties back in the .zip file - Rename the file back to .sh3f and import it to sh3d. Now, this does take some patience (and frustration), but if you really want to customise your design to perfection, it is the way to go. OR, you can give a specific description of you doors and windows - and with a bit of luck - someone might rise to the challenge and create your doors/windows. Good luck... ok |
Current timezone is GMT Aug 22, 2026, 3:43:12 AM |
