Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Error on save - string index out of bounds » » » » Post: Re: Error on save - string index out of bounds |
Print at Sep 19, 2026, 9:26:17 PM |
| Posted by fildy at Oct 21, 2013, 8:49:39 PM |
Re: Error on save - string index out of bounds I managed to recreate the problem, as you say it was not the .mtl file, it was caused by a parameter in the .properties file. The furniture could be used in the plan, but an error occurred when selecting "save". To solve the problem I deleted all instances of the imported furniture, corrected the furniture library file re-imported it again. When I created the furniture library (with items created from Blender) I copied the .properties file from a more complex model and edited them with a text editor, leaving the multiPartModel parameter set to "true" which caused the error on save. Using the furniture editor would have avoided that problem but I was doing things manually as I had another problem earlier with the way another program handled the .mtl file. Thanks for your help with this. |
Current timezone is GMT Sep 19, 2026, 9:26:17 PM |
