Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Strange behaviour in beta 11 » » » » Post: Strange behaviour in beta 11 |
Print at Sep 19, 2026, 6:43:32 PM |
| Posted by hansmex at Oct 19, 2013, 2:51:30 PM |
Strange behaviour in beta 11 Emmanuel, While doing some tests, I encountered strange behaviour in beta 11. Attached you will find 3 files, all made with beta 11. test3a - shows a pavilion with invisible walls and a pointed roof. The walls have been made invisible with invisible, insertable boxes. That´s a trick I often use. Problem 1: When I added invisible, insertable triangles on top of the diagonal walls, the walls didn´t disappear correctly when making a photo (Q3 and VV). Problem 2: After saving the file, exiting the beta, and reloading it, the 3D window wouldn´t display anything at all. Wondering what might cause that behaviour, I started deleting a few items, saving the file again, closing the beta, restarting the beta, and reopening the file. This resulted in files b,c,d,e, and f. I only attach test3e and test3f. So, when I finally delete the last invisible boxes, the 3D window is active again, and correctly displays the remaining four walls. I´ve never had any problems using invisible boxes before. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 19, 2026, 6:43:32 PM |
