Print at Oct 22, 2026, 2:19:11 AM
Posted by hansmex at Sep 24, 2013, 1:36:18 PM
Re: Splitting walls and joining them?
What you want is not possible in SH3D.
You are correct in assuming that walls are "reigned" by their centre lines.
Top - these walls can be joined.
Middle - these walls can not be joined. Use absolute X,Y coordinates to correctly position the end of one wall and the start of the other wall on the same spot. Note that if these walls surround a room, SH3D will think the room is not closed, and you can not create a room by just double-clicking inside the space.
Bottom - these walls can not be joined. There is no solution (that I know of) to fill the gap using the walls tool. As a workaround you could insert a triangle to fill the gap (Import a triangle and rotate it). You can not auto-create a room, because the space isn't enclosed by walls, according to the program.
SH3D is meant as an interior decorating tool, not as an architectural design tool. I think it's highly unlikely that Emmanuel Puybaret will create the feature you want, because it would make the program too complicated.
