Print at Oct 22, 2026, 2:16:28 AM
Posted by perdrix52 at Sep 22, 2013, 12:56:23 PM
Splitting walls and joining them?
If I split a wall, and adjust the thickness of one section to be thinner than the other, then the join is in the middle of the thicker wall, with the result that there is a step on the inside and outside.
1) How to adjust the connection point to so that there is only a single step on a chosen side.
2) Bonus points to adjust so that the joint is at an arbitrary position within the thicker wall.
Another question. If I draw walls as a continuous operation, then there are arbitrary angled joints. If I draw two walls I don't see how to "Join them together", I can only draw the new wall so it is "buried" in the other wall which doesn't feel like it is the "right" way to do things!
Thanks
Dave
