Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Objects and textures not saved. » » » » Post: Re: Objects and textures not saved. |
Print at Sep 15, 2026, 12:55:00 PM |
| Posted by Puybaret at Sep 20, 2013, 4:56:41 PM |
Re: Objects and textures not saved. First, you should take care to select the Add to catalog check box at the third step of Furniture import wizard, if you want to appear in the catalog afterwards. Note that this check box is not proposed (and active by default) if you drag and drop a 3D model on the catalog panel or if you open the wizard when the the catalog panel has the focus. If your models don't appear in the catalog, you can still copy the ones you added in an old document and paste them in the new document. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 15, 2026, 12:55:00 PM |
