Print at Sep 15, 2026, 10:18:47 AM
Posted by ErrorFinder at Aug 28, 2013, 10:18:00 AM
Re: Automatic dimemsion when you draw walls?
@puybaret
Hello,
thats true, but there are some problems:
1.If you create a room, mostly there a different thickness of the walls. For example here in newer buildings outside walls are thicker than those which are inside.
2.when you found out something, is wrong with the messurement, f.e. because on one side, there are three rooms and on the other side only two, but both sides must have the same inside length, you realize the thickness of the walls are different ore the you made a mistake by messuring the flat. When you now have to change the rooms, you have also to change the messurements of the rooms. And that costs a lot of time.
So my idea is, because the messurements of the rooms are already known by the program, why not combine the messure - lines with the rooms. For example click on the line of a marked room, hold the left mouse button and go to the position, where you want to have your digits. The same for the walls. And when you click on the edge of a room and change the position of that edge, the messurement is following it. Maybe this is much effort to program, you just build in a "recalibrate button" and the messurements are freshed up.
Or did I read something wrong?
Thanks for reading
