Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: RAM-Feature for Rendering - hope correct Forum ;) » » » » Post: Re: RAM-Feature for Rendering - hope correct Forum ;) |
Print at Sep 15, 2026, 11:26:34 AM |
| Posted by Pixelwizard at Jul 31, 2013, 10:32:37 AM |
Re: RAM-Feature for Rendering - hope correct Forum ;) Hi Hans, jep, i read the faq and i also understand that some models could use this errors, also to much objects etc. i guess in my special construction that also too much light sources could take effekt. in an older version i discovered, that when i group lights, rendering is impossible. ungrouped it worked well. my problem is basically that i don't really understand how to handle this command to use especially the jar version with for eg. 4gb ram. means, it is not clear to me if i have to edit the extra ini-file as for the win 1gb-solution or if i have to create a shortcut to the jar version with this commands... and the other part of the question was, if it's a problem to put the jar also to the installation folder of the installer - just to have a proper folder structure and anything on one place. so my idea is just to use the installer for eg. with 1gb ram for construction and the jar version with 4gb to render the high-res pictures i need... sorry, guess this was not really written clearly ![]() ---------------------------------------- WIN10 Pro 64bit * 16 GB RAM * AMD FX 6100 * Geforce GTX 660 |
Current timezone is GMT Sep 15, 2026, 11:26:34 AM |
