Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Cavity wall isolation » » » » Post: Re: Cavity wall isolation |
Print at Sep 30, 2026, 8:40:58 PM |
| Posted by hansmex at Jul 27, 2013, 1:00:16 PM |
Re: Cavity wall isolation SH3D doesn't have cavity walls. You can (easily) make them yourself by drawing 3 parallel walls. I suggest using exact X,Y coordinates to avoid overlapping. To insert walls and doors, use this trick: 1 - insert a (suitably thick) hatch or an invisible box by using CTRL + ARROW KEY. This will pierce your walls. 2 - using the same method, insert a door or window. This has the added advantage that you have more control over the placing and thickness of your door/window. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 30, 2026, 8:40:58 PM |
