Print at Sep 6, 2026, 11:50:33 AM
Posted by hansmex at Jul 12, 2013, 6:40:27 AM
Re: Insulation
Babsi,
No, there's no simple way to do that.
However, you could draw double (or triple) walls, using exact coordinates, then use Modify walls -> Pattern in plan to distinguish between the walls.
Personally, I draw my cavity walls 30 cms thick, which is the standard in my country (10 cm outside wall, 10 cm cavity/insulation, 10 cm inside wall).
