Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problem with File open » » » » Post: Re: Problem with File open |
Print at Sep 6, 2026, 9:45:50 AM |
| Posted by hansmex at Jul 11, 2013, 1:00:56 AM |
Re: Problem with File open Luis, The problem must lie with your computer. I'm using SH3D v4.1 with Ubuntu 12.04 and it works just fine. HOWEVER... I had to change one thing: - uninstall IceTea Java - install Oracle (Sun) Java. After doing that, v4.0 and v4.1 worked fine. There are a few small problems with version 4, but I'm not sure what is causing them. - Every now and then when a window pops up (e.g. Modify Walls), it doesn't display fully. I have to hit ESCAPE and give the same command. Usually then it works correctly. - A second problem is that when I have minimized the SH3D window, it doesn't restore correctly. Sometimes it pops up much smaller, sometimes half the window is blank. @Emmanuel - There also seems to be an old problem that is re-appearing. When entering negative values, the cursor hangs after the first decimal digit. So, -0.45 comes out as -0.54. This problem existed long ago in version two-point-something (I think). I have to check whether it is easily reproducible. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 9:45:50 AM |
